Roof gutter clamps
Has anyone use a gutter clamp to install the eufycam? I don’t want to drill holes into it to install anchor. There are various gutter clamps for branded cams on eBay and Amazon. But wasn’t sure whether eufycam could fit on any. Any ideas how to install on a gutter would be great.
Thanks all.
You can give it a try, if they don’t work, just send them back
Old posting , should be solved meanwhile!
