I cannot figure out how to dry the inside of the water reservoir when emptying it after mopping. I don’t want to leave it wet as mold may eventually develop.
Does anyone have any suggestions?
You know those moisture wicking packet stuff you get when you buy merch? Maybe you can start to horde those and create an army of those silica ball thingies and then contain them and toss in your vac in the same container … or just put it in raw rice or brown rice… idk
