Roav DashCam C2 Pro Mount Screw/Nut
Hi,
My Roav DashCam C2 pro mount screw recently broke falling off the window due to cold weather(I’m assuming anyway). Is there anyway to get a replacement? Otherwise my dashcam is kinda useless :frowning:
Your best bet is to send an email to support@goroav.com as they will be better able to assist you. Alternatively you can use the in app chat and talk to them directly if available
Thanks!! I’ll try that!
Mine fell out too, had to put a long metal screw/nut in to replace
For those who have broken mounts or wish to mount their camera differently, you can always buy This universal mirror mount
