Review of eufy RoboVac 30C by Anker
I just realized that @AnkerOfficial must really like your reviews! They pinned this one twice :joy:
I would hope so :blush:
Very well reviewed. thanks for showing me this vacuum cleaner robot. Recently i have also review best vacuum cleaner on blog. Thanks.
Yes!! This is a very detailed review! We love it!
Hope getting “pinned” twice will not cause more pain than being pinned only one time.
:rofl:
Here’s another example of anker using lots of wasteful plastic in there packaging!
How so? Would you rather they use all “wasteful” metal?
Your comment doesn’t make sense as plastic is used in just about everything.
Everything where it is needed not for packing
And at least that Metal gets used every day in there product not something you throw away once you unbox it
Great review! Very informative and great pictures.
Not understanding your reply at all.
I guess if you have a problem with Anker, I’m sure they have a Feedback form somewhere on their web site where you can address your concerns.
There are too many who dont care.
So we will be drowned in garbage.
I am wondering if the magnetic strips will work properly under carpets or must robotic come directly in contact with the strips?
I dont have that type of Vac.
but I am sure there is no direct contact needed.
It should work when the strips are under such a carpet.
The magnetic strips are of low magnetic power, so putting them under carpet wouldn’t work. They need to physically contact with the vacuum to prevent it from entering that space
I love that you took the time to really get decent shots of the app.
Nice review!
Thanks
Glad you liked it
Great review!! Good pictures!!:+1:
