Replacement water tank for Robovac L70 Hybrid
Because the water tank takes a long time to dry after mopping, it would be nice to have a second one to attach to the dust collector so I could run the L70 while the first water tank is drying. Alternatively, a replacement for both the dust collector and the water tank would work.
It would be nice if they sold the part separately
You should ask the support.
Your proposal is a real useful one, so it should be given some attention.
