I have a google Pixel C. It has a single USB-C port.
I bought a 1TB external HD that I can connect to the USB-C port. However, the Pixel is then providing power to the drive which drains the tablet’s battery faster when I’m using it.
Does Anker have a product that can split the USB C port so I can externally power (either by battery of AC) the tablet & HD while the HD is also plugged in to the tablet?
I want to watch movies on long flights. I can provide power but not at the same time the HD (with the movies) is plugged into the tablet
Does Anker have a product like this? If not has anyone seen anything like this? The this challenge physics with the power coming into the tablet and going out to the HD through the same cable (even if it’s split)?
Thanks,
Frank.
