- Firstly try to forget the pairing records(both Soundcore Life XX and Soundcore Life XX L) on your device and turn off the Bluetooth.
- Reset the earbuds per the steps below.
-Place the earbuds into the charging case and make sure they are being charged.
-Press and hold the button on both earbuds for 3 seconds. The LED indicators will flash red 3 times and then turn white.
- After the reset, take both earbuds out of the charging case to make sure they are successfully paired; you will see the white light flashes quickly on the one earbud and the light flashes slowly on the other side, which means they pair together.
- Turn on the Bluetooth again and search for Soundcore Life XX and pair.
Note: When there is a pop-up window for you to confirm pairing. Select “pair”. If you select “cancel” accidentally, you need to delete the earbuds from the device’s Bluetooth history and re-pair the earbuds.
