Premium lightning cable vs powerline+ ll
Hello I’m wondering do both the premium lightning cable and powerline+ ll have the same charging speeds? I’m currently trying to decide if I should pay more for the powerline+ ll my main focus is charging speeds. Thanks
Yes, all MFi certified Lightning cables should deliver the same (or very similar) charging rate.
Should be the same spec. Only difference that I see is that the PowerLine+ II seems to have a more rugged cable boot.
I believe they are the same speed, plus the Anker cables are built better so they last longer. This is why I use them to charge my phone now. Saves money too!
I don’t use anything but PowerLine+ II lightning cables now. They are second to none! That being said, charging speeds will not change at all.
Should be the same or pretty near as
