What’s Included:
-Power Cable
-4 Port Charger (1 USB C 45W, 3 USB A 20W SHARED)
I really like this charger. I was able to remove the chargers I used for my iPhone, iPad Pro, and Apple Watch from my travel bag since this little charger can handle all three at once! I went from three chargers down to one. That’s a decent amount of space I was able to save in my backpack. I like that I don’t have to dig around in my “Always Need You, Never Want To See You” bag where I keep my cables and chargers.
Look at just how slim the PowerPort Atom is!
Another benefit that I didn’t realize until I started using it during my trips was that I only needed to plug in the PowerPort Atom instead of three separate chargers. That might seem like a trivial thing, but it makes a difference when you want to go to bed as soon as possible in a hotel room. Overall, the PowerPort Atom III Slim is a great charger. I would highly recommend for those that travel and want to have a simple charging solution. #UseAnkerInstead
Amazon Review: https://www.amazon.com/dp/B07ZCGYP27?ref=cm_sw_em_r_rw_dp_oOCAnmrfQM7ka
Twitter Review: https://twitter.com/JacobTWebb/status/1206589901837201408
