hey guys! here’s my thorough full review, after using this cable for months and i will explain in the review what my thoughts and impressions of this cable and compare it with the powerline II. now lets get started!
the packaging of the cable is like any other cable which comes in a simplistic box and happy or not happy paper which comes in every anker product.
Build quality:
I’ve been using this cable for a while now to charge my iphone and ipad and it works great. it has superior build quality compared to the powerline 2 and is also thinner than the powerline 2. the cable feels good in hand and because of the non slip grip i can plug it easily in my ipad/iphone.
aesthetics of the cable:
the cable is white and i feared that it could get yellow over time however the cable will not after using it for a while it has stayed white which is great!
function: provides my iphone with charge and can transfer data perfectly .
bend:
anker says that the cable has over a 25000 bend lifespan which is great as this will last longer than the powerline 2 and is also thinner.
conclusion:
after testing this cable for a while i can say that this is a great cable for everyday use as its more durable and much better build quality compared to the apple cable which is pretty expensive. however, personally i would recommend purchasing a longer powerline 3 cable as it was quite short when using it besides that i would rate this product a solid 9/10 cable and would recommend this to anyone purchasing a cable.
hope you liked the review… i’m posting pictures right now
