I'm in the process of purchasing a few lightning cables from anker but am undecided between the the dura II and the powercore+ lightning cable either the nylon braids. Would love some feed back. Also I'm leaning towards the 2 pack of powercore+ lightning cable 3ft because I like the travel pouches that come with them. Makes it easy to bring along for travel and keep things neat
Your feedback would be greatly appreciated
I take it you mean the Dura II and Powerline+ cables? Myself I would go for the Dura II as they are cheaper, have a higher bend rating and a lifetime warranty should you have any issues...
The Powerline+ cases are a nice touch (I have a few) but past using for storage I prefer the pluses of the Dura...
Thanks for your feedback
Also I notice you moved my other post to the correct bog forum, thanks for correcting me
No worries, just seemed appropriate under @AnkerOfficial own thread.
The Dura is newer, more durable, and cheaper, so I would recommend the Dura. Also, it's not the PowerCore+, but rather the PowerLine+Who knows... we may be seeing a PowerLine+ Dura soon...
I ended buying 2 of the 3ft dura lightning cables thanks again for the feedback
I wish the Dura came with a pouch like the +
Me too. I just got my first powerline ii and I miss the pouch
You can now purchase PowerLine+ w/o the pouch if you choose.
The Velcro straps that come with them always fall off. Kind of annoying and I lost one of them already
If I understand correctly, the PowerLine II is now considered to be top-of-the-line, so why is the PowerLine+ more expensive—almost one-third more expensive?
