PowerExpand Elite Thunderbolt Dock USB and Aux not working
PowerExpand Elite 13-in-1 Thunderbolt 3 Dock USB an Aux not working. I’ve got my headphones and my external hard drive plugged in and they don’t show up. I installed the things. I checked my drivers. I uninstalled and reinstalled the things. I plugged a dongle into my laptop and things worked fine. Is there any way to do a factory reset? What should I do?
If it works on one device and not the other make sure the port you are plugging it into in the device that is not working is indeed a good and functioning port and if so go to device manager in windows and ensure that it is popping up and is there.
Thanks for responding, I should have been more more clear. I plugged in a dongle, not the dock, to make sure my computer was not the problem. The dock is the problem.
See if you can get it replaced
It sounds like your dock isn’t working and will probably need replacing but it could also be a faulty USB
C cable. Also, Has this dock ever worked before?
Yeah, that’s what I was afraid of…I did check the cable, and no it hasn’t worked before. Guess I’ll see about a replacement. Thank you.
Yes, I’ll do that.
