PowerCore+ 26800 recharge when powering 2 dashcmas in EV car
Hi,
I purchased the PowerCore+ 26800 to power my 2 dashcams 5V each ( front and rear ) in my EV car.
My question, can I power the 2 cameras both at the same time as I recharge the PowerCore+ 26800 over the car USB port ? is this safe for the PowerCore+ 26800 ?
Or when I recharge the PowerCore+ 26800 I should disconnect the 2 cameras from the PowerCore+ 26800 USB ports ?
I want to use the PowerCore+ 26800 for the cameras parking mode.
I don’t want to damage or overheat the PowerCore+ 26800 trying this procedure.
What do you recommend ?
Thank you.
Kind regards,
João P. Santos
Hello @pascoal2010 , when you charge your powebank, the other ports are automatically shut down. So either you charge something with the power bank or you charge the power bank. :sunglasses:
I get it. Thanks Pauldey.
100% percent safe to leave all cams chargers and power bank connected all the time. Just place the power bank somewhere it will not get direct sunlight I’m sure you remember the good old days of VHS tapes.
