Just purchased Power Core 10400 mobile charger in the U.S. Planning to go to Europe next week. Can I plug the charger into the wall, or must I first plug a converter so that I do not “burn out” the mobile charger? Recently purchased a different brand and AFTER ONE USE IT WAS KAPUT.
Power core conversion
You can plug the Power core in to the mains using any euro charger at all, if you don’t have a euro charger then any adapter will work like this:
depending on which countries you visit, that is for UK above.
Not sure why your other brand went caput but it happens.
I have been taking my PowerCore Fusion from US>UK several years now and it still works just fine
Hey @ephremhecht
Yes, as @neildutta mentions.
You can pick up the adaptors quite easily in most chemist and supermarkets, well at least here in the UK anyway.
Happy travels.
