FYI
A new Beta GMS Firmware for the Nebula Capsule Max is available…
Currently it is installing on my device
Let you know if I find new things…
FYI
Ok, found two issues with the new firmware:
Can’t anymore connect with Nebula Connect for iOS with the Capsule Max.
Tried to delete the app and reinstall from Apple App Store, reboot the iPhone and the Capsule.
The Connect app find the Max as a new device but can’t connect.
After switching on the remote between mouse mode and standard mode for some times ( 2 or 3 times) the remote buttons do not react anymore in the standard mode.
You need to reboot the Capsule to fix it.
