Nebula Survey
This should fall between Nebula’s Capsule and Mars series.
200 ANSI lumens seems to be the value
Real challenge for Anker / Nebula team would be to overcome the limitations of high heat (needs more cooling) and higher resolution in a compact size… get 200 ANSI lumens brightness, at a higher resolution 720p (or 1080p – this would be awesome) in form factor of Astro (or even sleeker) …
This is what Nebula Should strive to achieve , instead of releasing more and more projector of 100 / 200 ANSI lumens projectors of bulk …
Fully agree.
Innovation is required in light emitting, cooling, not just small variations in software. The Astro had not innovated, just a different package of old electronics
I think what would make me buy is Mars II Pro 500 lumens, 720p, in Capsule size.
Ah, I see where the Solar and Solar Portable came from! Love the names!!!
It’s been 4.5 months since this reply, Vega is the high end model, right? I did some peeking and found Anker’s Japanese website which shows the Vega with 100 more ANSI lumens and an extra watt for each speaker.
