If you buy the sligjtly more expensive ones they come with semi cut foam. Its “cubes” with a small attachment to each other. You just pull out the cubs you dont want, leaving you with perfect cutouts.
Nebula Mars II + Stereo Souncore Flare + Nebula Tripod Case solution
@brajner That’s some serious set up you have. I love the layout. Looks like it was meant for that too.
Cool setup. I was thinking about doing something similar for my tech gear. Thanks for sharing it gives me a better idea how this work for my needs.
How stable do you find the smaller capsule tripod with the Mars? I’m looking for a tripod and like the portability of the smaller one. The threaded hole on Mars for tripods to screw into is too shallow for the the tripods I’ve tried with it up to now?? Do you know why? Thank you
