Nebula Cosmos Max USB power
Hi,
I know my Nebula Cosmos Max has 2 USB ports so that you can connect flash drives etc but do these ports supply power out? I want to connect a Bluetooth transmitter and be able to power it using a cable from one of the Max’s USB ports. Is this possible as it doesn’t mention it in the manual?
Thanks in advance.
@boasey I would suggest dropping support@seenebula.com an email for confirmation.
As they are USB 3.0 ports and the Comos Max has its own mains supply, I would think they would be able to output some power.
