Nebula Capsule 2 or Capsule Max
What are the differences between these 2 products? Trying to decide which one to get
Here is the table for you to understand it!
What that table does not show is the fact that you can charge the Capsule II (via USB-C) while playing files from a USB-A memory stick, something you cannot do with any other Capsule.
So, the addition of a USB-C power bank (Anker, of course), massively extends your run-time.
The Capsule Max is far better with 2GB RAM and 16 GB ROM and Octacore Processor.
Android TV is really limited. Just contact Nebula for beta Google Service after you get the Max so you can enjoy the full android experience.
Hello,
A-J, i’m french, and i would like to buy a Capsule.
You write, what there is a beta gooogle service of the Capsule Max,
what are you going to get more?
I want to use it for netflix, and connect my iphone to broadcast too
thank you
You need to contact Nebula customer care for that. It’s a beta firmware which gives you google play service.
Thank you
i will be buy the Capsule Max and contact after the customer service
Hi,
I’m going to buy one or the other of these … however i cannot find an image of the connections on the Max anywhere. Is it because there is no USB C?
Let me get this 100% correct … can you or can you not charge the Capsule Max while watching? This is important to me for use at work. I certainly cant stop to recharge.
Thanks
You cannot on Max.
You need the II.
£100 off on Amazon UK deal of the day!!
[Nebula Capsule II Smart Mini Projector, by Anker, Palm-Sized 200 ANSI Lumen 720p HD Portable Projector Pocket Cinema with Wi-Fi, DLP, 8W Speaker, 100 Inch Picture, 3,600+ Apps, Movie Projector https://www.amazon.co.uk/dp/B07NPJF8BZ/ref=cm_sw_r_cp_api_i_rCGhEb6TGFBAA](Nebula Capsule II Smart Mini Projector, by Anker, Palm-Sized 200 ANSI Lumen 720p HD Portable Projector Pocket Cinema with Wi-Fi, DLP, 8W Speaker, 100 Inch Picture, 3,600+ Apps, Movie Projector https://www.amazon.co.uk/dp/B07NPJF8BZ/ref=cm_sw_r_cp_api_i_rCGhEb6TGFBAA)
