Nebula Capsule 2 crooked projection
This does not appear under projector settings anywhere or device settings!
Did you just recently purchase a nebula 2?
Alright Anker Community…
I believe I have found an answer to my own question here… I’ll provide some insight.
The projector has a nice auto focus feature if you hold down the HDMI/ATV button for 3 seconds. It won’t necessarily fix the lop sided projection BUT… The projector itself adapts to its environment and auto corrects itself. I was watching in the living room and placed it onto a flat surface roughly 3.5-4 hours in it automatically turns off briefly for 0.01 seconds then corrects itself. To test this theory, I put the projector onto the tripod and projected it onto an uneven white surface. Did not change the settings but just watched it for hours. The projector again adjusted itself.
This is not a quick solution or quick fix but this is what I noticed after having it for a week or so.
Has the nebula capsule 2 horizontal keystone correction ±40’?
Hi,
Did any one find the solution for this. I recently purchased Nebula Capsule 2 and facing same crooked projection issue :frowning:
Regards,
Puneeth
Did all of the fixes above failed?
Yep. There is really no fix mentioned above. It’s just an adjustment via tripod.
