Naming rooms on L70
Hi,
I love the Google integration for eufy l70, just being able to say “OK Google, tell Spot to go clean”, or “tell Spot to go home” when I need it to be quiet during a phone call is so easy and handy. (Spot is my robot’s nickname in the app)
However, I would REALLY love to also be able to say “OK Google, tell Spot to clean the kitchen”
The floor plans spot creates of my apartment are pretty good, and I can already mark cleaning zones in them, but if I could also name them in the same tool then voice commands like that would be so simple.
Also you’re probably already aware but the Alexa version of the integration doesn’t accept the robot nicknames, only Robovac. (Not important though, not worth wasting too much time over)
Thanks,
–thavidu
