Hey All - Anyone have the problem where - when connected to your Motion+ via Iphone, the volume increase is incremental in the sense that there are clear “tiers” of volume that you reach using the volume slider. This is within any app, not just the soundcore app. It’s like there is a knob with 10 settings, and you are stuck on one of those 10, instead of, say, the 50 or 100 variations that the iPhone volume meter allows.
To go further down the rabbit hole, when I first linked to my laptop I was having volume issues, and found this solution - Can't change volume via windows by entering the Registry Editor and “disabling Absolute Volume”.
By doing this, I’m making the volume control from the speaker, seperate from the volume control on my electronic device. This way I can set the speaker at 90% volume, and control the rest from my device, using my windows volume, it sounds amazing.
The issue with my phone may stem from a similar situation, but I can’t know for sure. Is it possible to make the unit volume in the Motion+ static, and then it interprets my Iphone volume in a “smoother” fashion? Any help would be appreciated, thanks!
