Hi. I could use some help, please!
I bought an Anker 4-Port USB 3.0 Unibody Aluminum Portable Data Hub with 2ft USB 3.0 Cable for Macbook last fall and it’s everything I could ask for in a hub. However, the connector to the MacBook’s USB port isn’t snug and jiggles, apparently causing a lot of static/crackles in my headphones. After a while, it makes me nuts. If I gently press the connector tighter into the port the static all but goes away.
Any suggestions are welcome.
Thanks!
Best regards,
John
