My old desktop only came with one USB-C port. I need at least 2 USB-C data ports, preferably 3. I thought I could find a USB-C hub easily, but nearly all of the USB-C hubs give you multiple USB-A ports and only 1 USB-C data port. Some have 2 USB-C ports, but only 1 is data and the other is PD (input) to charge the laptop. I don’t necessarily need PD …
Seems like the only Anker products with multiple USB-C data ports are their docks (>$200) or the one made for MacBook. I found a few from other brands, but they are ridiculously priced and/or not so great reviews:
Hoping to spend <$30. Anyone have a good experience with a USB-C hub that gives you multiple USB-C data ports?
