I bought the Soundcore Liberty air last week and iv been noticing that when they are connected to a device and playing something they continuously disrupt the wifi network,(y i know that both wifi and bluetooth work on the same range 2.4ghz and that there are some interferences) but not to this point, my internet connection wich is usually 10-15 Download speed with 20ping gets around to 0.7-1.5 with 200-400 ping when it works at all, iv tried other bluetoth devices including another bluetooth earphones and they work fine (the change is around to 6-9mb with 20-30ping )
The problems seems to precists in more that one wifi network and in both my pc and my phone
I have tried changing channels on my router but it didnt work (havent tried using a 5ghz network since none of my routers suport it)
Is this a known issue?
Are my earphones defective?
