Hi. I’m totally new to projectors and have just bought a Cosmos Max. The picture is stunning but I have noticed some dust on the inner lens behind the front glass panel. Obviously when the lamp is on it will show up every spec of dust but I would have thought a brand new device would have spotless lenses and be manufactured in a dust free environment. Is this normal? I just want to check as there’s no way to clean the concealed lens. As I say the picture isn’t affected so I’m probably worried about nothing but any comments would be appreciated in case I should as for an exchange. Photo attached. Thanks!
Lens dust normal?
If it doesn’t affect the quality of the videos I wouldn’t worry too much about it. I’d make sure it’s really sealed and if it is, then you shouldn’t have anything to worry about
Dust inside of the lens if fairly common for many devices, even phone cameras. It typically won’t affect image quality, but as @ikari04warrior noted, if it starts to become a problem, feel free to reach out to support@seenebula.com
