I have a K1280c which is old on the scale of things, but has worked well until today.
I have had it paired to my laptop (HP 840G1, W10 Pro) and yesterday paired it to another identical machine. Had some issues with code generation but finally worked through that. KBD worked fine. Disconnected the device from PC 2 (deleted connection in Win 10).
Re-paired it (twice now) to the original PC and indicates it’s paired but but not connected.
the power LED is flashing a slow blue (not the fast blue) and the KBD will not type (other than to enter a pairing code). Changed batteries. Power cycled. Not sure what else to do.
Unable to find a manual to ascertain led meanings. Any way to clear\reset, etc.
Are there any KBD shortcuts to any functions. Ideally would like to lengthen the time till it goes to sleep, which I think is about 30-45 seconds.
