Just as a final update, we now have some seriously nice weather; pure sunshine from 8am to 9pm which is fantastic.
So I’ve tested the powersolar on 3 separate days and it performs exactly as I hoped, it charged up my 65W 20,000mAh power power bank in a day with nothing else attached.
With cloud, it does have a temperamental ‘off/on’ attitude that means it supplies a charge one second, and then stops the next. This seems to be mostly when the light is near to the minimum threshold for an output. For this reason, I decided not to charge my phone on these days, but instead charge a power bank with pass through.
In response to iPhones being problematic with the charging setup, I can’t say I’ve found this issue at all? On the sunny days, the powersolar charges and the phone takes the charge without any complaints so this is good news. I’m using an iPhone 12 if that makes any difference.
I expect the performance will change depending on solar intensity/season/latitude etc but I didn’t buy it as a replacement for an AC mains charge, which I wonder might be some of the reasons for some people returning the item? I know and accept the output will be a fraction of a mains charger!
The important bit which relates to my OP, is that it seems the red circle is BOTH an indicator of electrical incompatibility with the device AND an indicator of insufficient solar input to output a charge. This isn’t mentioned explicitly on the instructions and so I think a lot of people might assume there is a problem with the unit when it is actually just isn’t getting enough light.
All in all a great buy for those outdoorsy people away from a mains charge
