Is it possible to balance between left and right?
Hello,
my left ear is more sensible then the right one so i would like to set the right side louder.
Is there any way to balance the sound? Maybe with an additional app?
Thanks
What item are you asking about?
Was asking for the Liberty Air 2.
I already found a solution: Samsung Sound Assistant App allows to balance between left and right ear.
But it would be nice to set balance inside the Soundcore App so i can balance on my other devices too.
If you open sound presences on a laptop or computer you can balance the earbuds there.
Sorry forgot to mention I was talking about Android Smartphones.
Sorry I can’t help you but you can reach out to @AnkerSupport for more assistance. If you click on their profile you can directly message them.
The following should help @420 though an option in the app could be a good improvement in a future update
Exactly what i was looking for. Even that simple and without the need for an App! I never looked into the Accessibility settings at all.
Would still be nice to balance inside the App. Maybe the app could even go a step further and EQ each ear individual. :sweat_smile:
Thanks a lot!
