Hello
I have a Mate 9, and I buy a powercore speed 2 with qc3.0 but the charging is very slow in comparison with the factory charger
Is different the fast charging from Huawei than the quick charge 3.0?
Hello
As I understand it, Huawei use there own version of Quick Charge 3.0 (and higher amperage, I believe), so performance of a Anker version would be different.
You could reach out to support@anker.com with your phone model and the charging times you are getting in comparison to the manufacturer charger for confirmation if speed should be slower.
