I fulled charged my earbuds and played music at 90-100%volume,my battery died in 4 hours,its normal?or my buds battery have problem?and i charged 10 min and i could play music 44 min at 70%vloume.
How much is the battery life of liberty air 2?mine is about 4 hours,its normal?
According to the site, you should get about 7 hrs of battery life on 60% volume if I’m not wrong so try to reset the earbuds and see if that helps. 5ish hours with your volume should be just fine in my opinion
At full volume and depending on how bass heavy the music is you can expect anywhere from 3 to 5 hours of use.
You have air 2?your buds work3 to 5 at full volume?
And my buds dont support 48hz,your buds support that?mine is 44hz
I have all of soundcore tws earbuds, and yes they last between 3 and 5 hours. If the music is bass heavy they don’t last as long at full volume, but even the slightest change in lowering the volume from max goes a long way in how long they last. So instead of listening at max volume try listening at say 90% and they should last a bit longer
Ok tnx bro
