Apologies this has probably been asked already but I can’t see a search bar for the forum.
so I’ve just got an anker 10000 pd redux to use as a supplementary power supply for a, oculus quest and I was hoping someone could explain how I charge it and how I charge things using it.
Maybe I’m having a senior moment but I just can’t understand the user manual.
The piece of paper that comes with the product laughably called a manual, is completely useless to me, as I don’t know what the diagrams are supposed to mean.
Assume I know nothing about the product but I just want to understand the basics like
can I use either port to charge the battery? I gather to charge it using the PD port I need some special charging wall socket but I aren’t fussed for that as I’ll probably just leave it charging overnight.
How do I know when the battery is charging. How do I know when its finished charging.
Can I use either port to charge things using the battery
what does the button do on the battery.
There’s a light that comes on when I push the button what does it mean when its blue/green (receiving a charge and charging a device I’m guessing but I’m not sure)
thx
regards
Kevin
