Hi there, I use the cam to check my garden outside. Setting everything up worked pretty straightforward and fine. (Once I figured that the SD card needs to be inside for alarms to work) Upon testing I found, that the cam triggers on my dogs though which is slightly suboptimal. Any suggestions on what I can do to prevent this?
How can I prevent Eufycam to trigger on my dogs?
Hopefully as the “SmartDetection” features improve we’ll be able to filter some of that out and have the ability to specify “Human Only”. In the first two days since my install I have caught not only my small dog (French Bulldog) on the cams, but also a random cat on my deck, a squirrel on my front porch and a fox on the driveway.
