I have a Eufy Cam Homebase and the last few days the LED has been going from the white solid light to combined white/red to red then back again…
I have reset the homebased and reformatted the SD card and its still happening…
Is the homebase saying anything about losing internet connection? I know this happens when our internet goes out. It goes from white to red as the homebase intents to re-establish itself. Anyway, try connecting a different cable from router to homebase or reboot router. If using homebase wireless then reboot your router, check if problem goes away.
Doesn’t say anything about the connection , I’ve rebooted router - using wireless and even tried the ethernet cable and still does the same thing…
white led comes on and after a while (could be 5mins or hrs) the red/white then red led comes on the back to the white led.
YIKES! At this point I would be contacting support@eufylife.com I have not had the same issue you are facing. Hope you find a solution.
tried contacting support@eufylife.com but get -
‘support@eufylife.com’ on 11/01/2020 1:05 PM
Server error: '550 #5.1.0 Address rejected
hmmmm
Looks as if their server is down. I tried https://www.eufylife.com/support and get nothing. Try the link or try this one to submit a request https://www.eufylife.com/exchange
