Homebase 2 network storage
How to set up the homebase 2 so it will store video recordings on external network storage like a NAS.
Post your question here as well:
communitysecurity.eufylife.com
Good luck :+1:
@fredrik.chabot You would need to setup/configure RTSP. Link below is an example of setting up with Synology surveillance station.
You might have more in depth instructions on the dedicated Eufy community linked by @ikari04warrior
This might, or might not work directly with the mentioned camera.
It doesn’t with the Homebase 2 as is, even though it appears to be listening on port 554 I cannot connect.
As far as I can tell, the Homebase creates a dedicated hidden Wi-Fi connection to the doorbell, so I don’t think I have a direct connection with the doorbell or its camera.
