home base eufy cam 2c
hi can anyone tell me if you can turn down the home base alarm volume when its going off i know you can turn it on and off
regards
wayne
You could ask there as well :
Go into the Eufy app, on the main page you will see your cameras and somewhere on that page you will see the homebase…click on the gear wheel next to the home base> then go to Alarm settings> adjust the volume to your needs, here you can look change the type of alarm tone you hear
