Geofencing for the cams is working pretty well however I would like to have the ability to disable the siren that goes off on the cameras. These options are available in all other modes, with the exception of geofencing?
Geofencing alerting options
@The_Craigs as in my photo you need to change in the mode you have setup for home or for away then it is selected in Geofencing the one that you want to use. I hope this helps have a great day
Hey @The_Craigs, thanks for reaching out!
In order to further assist you in this case, please contact us at support@eufylife.com.
Please provide us your eufy account and also the alert trigger time, we will have our engineering team assist you with this case.
