Hi there,
I have replaced my wired CCTV with EufyCams and must say i’m impressed how easy they are to use. My only issue is that both my front driveway cameras trigger too slow and sometimes completely miss someone who’s coming onto my property!
My old Wired CCTV cameras used to record indefinitely to my NAS and i’d set it up to get to a storage limit and then over-record. This mean’t I had around a months worth of 24/7 recordings, which was a bit of a waste of storage. So decided to change to Eufycams and motion detection. I’ve still got to experiment with the motion side and get the sensitivity correct, however I still get frustrated when the cameras trigger but miss things.
Has anyone got any good tips how to set up the triggering side? I know you can set the cameras up with a custom set-up and change the triggering rate, however I have also heard this does impact the battery life.
Any other options/tips please
