Eufycam 2 Mounting Bracket
Just received my Eufycam 2 set from BB. I need to mount the cameras parallel to the mounting surface but the included mounts don’t support this. Does anyone know if the camera’s screw-holes are the same as the Arlo’s? If so, I know what brackets to get. Thanks.
The included screw-in permanent mount will be flexible to have the camera in any direction. Don’t think you have to purchase additional brackets or mounts.
Please provide more details so we can help you :slightly_smiling_face:
If the mounts are the same as the 1st gen you should be able to adjust to most positions as @Ice1 has mentioned…otherwise as long as the mount has a 1/4” screw thread (like a camera tripod) that should be compatible…
