Eufy Robovac Starts Cleaning then Powers Off
Recently, my Eufy Robovac has stopped working. I can start it, it says begin cleaning, leaves the charging base, turns around and then powers off. The only way for me to get the power back on is to place it back on the charging station, where it all happens again. There is no beeping, just a power off.
Please help!
Thanks,
Cliff
That’s an odd behavior, email support :+1:
Try this : Open battery case, remove battery and insert it again after 3 minutes.
This action will not touch the warranty if there is.
Its a kind a reset of course.
Otherwise have you checked all if its clean, eg the bumper is moveable etc.
And you can check the battery power of it is disconnected.
