eufy Robovac 25c parts
Do replacement rollers, side brushes & filters for the eufy 30c fit the 25c model? Are the dimensions the same? I can find nothing that lists parts as 25c compatible but the look identical.
Its always difficult to find out.
I found a middle roller brush at amazon. de without any specification.
After an email they added the correct model.
Fine, so far.
Best would be to contact the support and get it confirmed.
Yes - replacement rollers, side brushes & filters for the eufy 30c fit & compatible for the Eufy Robovac 25C model
This is the kit available on Amazon, on a sale for $19.99 ($10 lesser than regular pricing)
you may also reach Eufy Support support@eufylife.com to get more details on them
