Eufy PoE CCTV Cameras
I would love to see a Eufy CCTV camera that can be permanently powered over PoE rather than rechargeable only.
Thanks
SI
Would be a useful model for some setups :ok_hand:
Route I’m about to go down, decided on dahua starlight system, just need to decide on NVR & actual camera models
Any particular reason why you chose a dahua starlight? i’m considering HikVision colorvu, not looked at dahua yet
They are both good at low light but dahua are slightly more customisable with settings & slightly cheaper
Comparisons I’ve looked at say like for like they are incredibly close at night but due to the available settings dahua can get a slight better image
From the comparisons I’ve seen the darkfighter are also poor in comparison to starlight or colorvu
Although 8mp are available I’ve been informed that the 4mp have the best night image as they use a large sensor so can pickup more light
Hmm they could work great if the price is right
