My Eufy leaves the docking station on time but immediately returns to the charging station. Why?
EUfy leves base on schedule but turns aroubd and redocks.
You are talking about a RoboVac, OK.
Which model is it?
Have you “programmed” a schedule with your remote
or are you using the app for such a schedule?
What happens when you start a cleaning program “by hand” using the remote.
Try resetting it
