Hi, is there a way to receive notifications when the battery is low? I just realized the battery was down to 4% and had turned off.
eufy doorbell camera T8210 low battery notification
You might also try contacting Eufy support. If you go to https://www.eufylife.com/support/ and scroll to the bottom it gives you options to contact support.
This would be a handy and useful feature
