Have two cameras set up in my primary home, they work great.
If I get another home base and a couple more cameras can I set them up in my weekend home?
Can I use the same app or do I need to install a the app on a different device?
Hi @Craig_Schieve you can add multiple Homebases and cameras into the app, so the setup you are wanting to have can be completed under the app. Also if you install the app on another device, your setup configuration will carry over to that device once you are signed into the app with your Eufy account.
