I bought the Eufy Camera System through Kickstarter last year. I was curious if there is any way to integrate the system with a security system such as the one Ring puts out. I guess more importantly I would like to integrate the door senors with the security system. Thanks for any and all help.
Eufy Camera Integration
Hello!@Blake_Krek At the current stage, both the eufyCam system and eufy entry sensor need to be added to eufy security app for use. They connect with the same HomeBase. Could you please confirm whether the door sensor you mentioned is your original one? Thank you!
