I had an electrician install all my Eufy devices a few days ago.
As I understand it, on your phone app, for each device with a camera, you can set “activity zones”.
My front door camera can see cars in the street too, but they are not reacting to this.
On your phone, first go to DEVICES
Get to CAMERA SETTINGS for your device
Scroll down to MOTION DETECTION and click on that
You will see categories. Mine are in this order:
Motion Detection
Activity Zone
Detection Sensitivity… etc.
TURN YOUR PHONE HORIZONTAL in LANDSCAPE mode instead of Portrait mode so you can see the biggest possible screen.
Click on the one that says ACTIVITY ZONE.
You should be able to tap the screen and see 3 icons.
A trash can surrounded by red…
A check mark in blue
A plus symbol in blue
Each time you hit on the plus symbol…
You will see a new green square. Adjust that square to the areas that are where people will be.
Then when the green square is placed where you want it, click on the check. You will then see that kind of “clock” symbol saving your square. This saves your square target area.
Do the PLUS again to get a new square to cover another area. Avoid the areas where cars are.
When you like how that is placed, click on the check to save that one.
If you want to change or get rid of a square, highlight the square with your finger and touch the trash can icon.
I’ve not tried to add more than 2 squares.
They are also layered in a sense so to get rid of one that is smaller and happens to be ‘behind’ another you’ll have to move the top one to get to the bottom one. Then move the one you want to keep back where it belongs.
I save things again before closing a window to be sure it’s saved.
This should help!
