Looking at the eufy alarm pad to add to my current set up.
Does the pir sensor on the alarm pad (that lights up the buttons) also act as a motion sensor? IE if I just had the alarm pad on the wall with no other entry/ motion sensors, would it set off the alarm once set if someone triggered the our on the pad, or do I need entry sensor or motion sensor?
