I’ve 3 off 2c cameras fitted. The picture quality is superb. The microphone gives clear speech on all 3 cameras but when I dorks it’s like a sales or I’m taking using a kazoo ( cheap musical toy). Does anyone have a solution? Thank you. Graham.
Eufy 2C cameras
When you what?
Check to see if it has the latest firmware
Hi yes. They all have the latest software. As does the Homebase. It sounds horrendous.
I’d recommend contacting support about this. Best of luck
