Eufy 15C max robovac in small apartment and narrow places
Hi everyone,
I have found the Eufy robovac 15C max on Amazon (UK) with a 90GBP discount voucher, and I’m just about to buy it. But before I do, I wanted to hear your experience with the vacuum cleaner.
I live in a small one room studio apartment. So in that sense the random navigation vacuums are probably great for my apartment (I’m assuming they work better on smaller areas).
However, since it’s a small studio apartment, the apartment is a bit crowded and have some narrow corridors between some of my furnitures.
So do you think eufy as a random navigation bot can handle this? Or should I give up on getting a robot vacuum yet? (The robots scanning the room and etc, are simply outside my price range).
The robot gets everywhere according to its height and diameter.
The apartment’s area size doesn’t matter.
Problems are : carpets ( high pile), cables, high door steps and those “cantilever chairs”.
I own a stupid 11S (no map, no app, its a “Depp” (german) )
Works perfectly since 2 years.
The more you care about the longer the robot lives. :smiley:
I would go for it, Helps you a lot.
I am not such a tech geek, but meanwhile I would miss “old Willy” (robot’s nickname) :rofl:
Hi there @mjmnr3
Just get one, you won’t be disappointed.
As @Chiquinho I have the 11s I’ve been using it daily since December and wouldn’t be without it.
